Old 08-14-2015, 04:15 PM   #1
Painter
Liked 162 Times in 45 Posts
Default Re: How to get brake pedal out of 89 Mustang
A line lock on each front wheel sounds like a major invitation for disaster. Rethink this please. It might have been easier to install, but a problem with one makes the turn, and there is nothing you can do about it.
Painter is offline   Reply With Quote
Old 08-14-2015, 08:16 PM   #2
partsbob67
Liked 79 Times in 11 Posts
remove the drivers seat, then the dash assy complete. easiest way I have found when I did mine.
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 08-14-2015, 09:40 PM   #3
Slickfoot
Liked 2 Times in 2 Posts
So far I got seat out , lower dash out, upper dash out, and I have to see the nut toward the pass. side yet. called it a night. hit it again Saturday
Thanks for the reply.
Slickfoot
Slickfoot is offline   Reply With Quote
Old 08-15-2015, 12:05 AM   #4
Eman
Liked 133 Times in 76 Posts
I've been able to just remove the bolt but it's probably easier to remove the whole quadrant. If you remove it all it makes it easy to mock it all up including mounting the MC. You can make a guide for the brake rod and weld it in so it would be impossible for it to pull out of MC and fall down. I've also mocked it all up and bled the MC by pushing the pedal while it's all in a vise, much easier. For a stop you can weld a piece of tubing at an angle and use a bolt in it with nuts on either end of the tubing as an adjustment.
Old 08-15-2015, 12:39 AM   #5
Rod Greene
Liked 242 Times in 81 Posts
So why not do the obvious and put a stick in it? A lot more fun to drive. It only takes 300psi to hold on line.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 08-15-2015, 03:22 PM   #6
Karl Owens
easiest way is the remove the steering column and the pedal assembly with bracket practically falls right out.
NHRA Stock/Super Stock 1078
Karl Owens is offline   Reply With Quote
Old 08-15-2015, 04:03 PM   #7
Slickfoot
Smile Re: How to get brake pedal out of 89 Mustang
It's out !!!! Thank God It's out
Thanks for all the posts and help.
Slickfoot
