Old 08-19-2015, 02:08 PM   #1
Tim Lisson
Default Re: EFI TROUBLE! ED W. All Cooters, Help!!
Oh, one other potential, remove all of your injectors and spray carb cleaner in screens and blow compressed air to dry. Reassemble. With batch fire your o2 will not show a dead hole on one side.
Tim Lisson is offline   Reply With Quote
Old 08-19-2015, 03:50 PM   #2
Tony Goodman
Liked 18 Times in 4 Posts
Turbo 200 trans, possibly broken stator support in the trans. Had that happen before, thought it was the ecu also.
Tony Goodman is offline   Reply With Quote
Old 08-19-2015, 05:32 PM   #3
Ed Wright
Ed Wright's Avatar
Not sure why you want to graph your air/fuel or timing. Not much use there. numbers versus RPM are all you need.
I think it's your converter as well.
Ed Wright 4156 SS/JA
Old 08-19-2015, 09:08 PM   #4
Liked 5,125 Times in 1,953 Posts
I doubt it's the converter.Of course I know why it always gets blamed. Black Magic.
So JR changed the engine oil and all of a sudden the converter doesn't work?
If the sprag all of a sudden decided to slip, the lower numbers would be down, but the MPH would be the same ..within reason.
Going the other way, if all of a sudden the vanes in the pump decided to fly off , the stall would be way high, and the low numbers would be off, but the rpm in the lights would be sky high. In this case ,it would last about one run, and the trans would be full of metal..
Back to the EFI guys...
Old 08-19-2015, 09:52 PM   #5
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Ya, probably the u-joints slipping.
Pedigo Perf is offline   Reply With Quote
Old 08-19-2015, 09:59 PM   #6
J.R. Haddad
Liked 1,469 Times in 308 Posts
Carson, thank goodness your humour is back!! Your Kyle sheep jokes
kept me going one very cold winter! So, I'll order the new u-joints in
the morning! J.R.
J.R. Haddad is offline   Reply With Quote
