Liked 133 Times in 76 Posts
Anyone run a 29.5 diameter MT slick on their 3rd gen Camaro? I was wondering if the diameter fits in the wheel well opening. I've run a 29 hoosier and it fits with no problem.
Liked 39 Times in 9 Posts
[QUOTE=Eman;479931]Anyone run a 29.5 diameter MT slick on their 3rd gen Camaro? I was wondering if the diameter fits in the wheel well opening. I've run a 29 hoosier and it fits with no problem.
If the offset is correct you shouldn't encounter any problems. My 3rd Gen is a Z/28 so I did have to "adjust" the ground effect trim panels at the front of the wheel well slightly. I use the MT 29.5 3056ST tire on 8" wheel. Be sure to roll or remove the fender lip.
Reggie Winkles 2650/Stock |
Do you remember what wheel offset you used?
I've got 5.5" BS, but could go to a 6.5" BS. I had 6.5" with a spacer. Now I've got more room behind the tire so it would work without spacers.
My concern is with the tire diameter in the wheel well. I see stockers run 30"x9". Surely if they fit a 29.5" will fit. |
