Liked 109 Times in 32 Posts
You need to run 12v to each prong as each controls 1 solenoid. There should be wires inside that ground each solenoid on the valve body.
Liked 4 Times in 1 Post
Ok that explains why there was no obvious change. Thank you so much for your help ill correct it tomorrow
I had a similar problem at Bristol earlier this year. As stated put 12v to both wires and you can shift manually. You may also want to put a test light on each point and see if it comes on with the corresponding lights to confirm there is actually power there before you pull the trans out. The boxes are a more common problem than the trans itself, but there are relays inside the trans that do go bad.
Are you refering to the contacts coming out of the E shift box when you say to check the contact points?
Yes that is correct. Put it in pit mode or lower your shift points and you can hold a test light on it when the little light comes on to confirm it is putting power to the terminal.
Liked 11 Times in 8 Posts
If you have access to an MSD ignition tester you can cycle the cheeta e as many times as you like to help with dianosing the problem. Testing the outputs would be the place to start, however if you can see the indicator lite come on I'd say the box is most likely working. Other issues of intermittent operation may be caused by simple wiring or conection issues, be sure to trace all the wiring.
Joe Buchanan SS/BX 3117 |
