Liked 695 Times in 206 Posts
I saw them fueling the Pro Stock cars the same way at Brainerd.
Liked 34 Times in 13 Posts
Do you think the Comp. guy's or anyone else are getting the same "SR-18" that the Pro Stock cars are getting? My guess is no!
They have been fueling Pro Stock cars at the back of the lanes for years.
Ed Wright 4156 SS/JA |
Liked 334 Times in 181 Posts
Yes they have ED BUT is it the same fuel everybody else is getting or that "special blend" only for the Pro's this time around--- VP has never ever had problems ---but Sunoco sure cannot say that ---FED 387
yes the "same" but is it really the same or is it SR-18 the street version???
Liked 10 Times in 6 Posts
The word around the pits is Sunoco wants NHRA to change to a specific gravity test instead of the dielectric test that NHRA has been doing for years.
Liked 706 Times in 283 Posts
That would open up cheating gas for sure. Many years ago it was gravity tested only and became very easy to alter fuel and get it back to the proper specifics for the brand being claimed.
Fine but if the gas is still garbage REGARDLESS of what testing standard they use how is this going to help???
In 1964, Dr. Dean Hill and Dale Schaffer started using a dialectic meter to check the gasoline. They quit using a hydrometer because they needed something more reliable that would catch people altering the fuel. The dialectic meter is still used today. We have a new meter that came out in the late 1990's that checks to the hundredths rather than the tenths like the old meter did. The new meter has a longer battery life and is easier to use. I was told by a Sunoco rep that they use the hydrometer to check the octane level to make sure that it is as advertised. NHRA does not check the octane levels. They only check to see if the fuel has been altered from the original manufacturers spec. We also have a chemical test we use. The dialectic meter also will indicate when the fuel is getting old or flat. Most all racers ask to see where their fuel is in reference to the chart. This gives them an indication as to if they need to freshen their fuel or put new fuel in the car. At fuel check, for me this is more to help the racer keep his fuel in line rather than catch someone cheating. I can tell when the fuel has been mixed or something has been added to it. It takes years to learn how to do this. I have taught an NHRA Fuel Check School for the last several years. This is for NHRA employees as well as I have also taught several foreign track managers and foreign fuel check people from other countries. This post was not approved by NHRA. Hope this helps.
