Liked 1,934 Times in 581 Posts
Well my season ended early at the Jackson pro am last weekend. The crankshaft broke right behind the #8 rod journal. Several runs before the broken crank I had an oil pump snap off at the neck and fell into the pan. The engine was completely freshened and had the crank turned .010. Might have been some residual damage from the oil pump hitting the crank. Also the #4 main bearing was burned pretty bad. Other than the #4 main all of the other bearings looked good. What are some of you using for crankshafts. I think the one in the engine might have been an Eagle lightweight. Super Stock 350/295/313 SBC 2.00" rod journals. Thanks.
Mike Pearson 2485 SS Last edited by Mike Pearson; 09-08-2015 at 10:18 AM. |
Callies has a really good stock and superstock crankshaft from what I have seen.
#3 | |
Liked 13 Times in 11 Posts
First time , ( in '01 ) a Manley aluminum rod broke. Crank kicked it right through the block. Last year....... I lost an engine from what I thought was a rod failure ( aluminum ) and turned out to be an oil pump bypass spring breaking ( no oil pressure ) . Sent the rod through the block , again. Last time.........recent , apparently the damage from the previous carnage above fractured / cracked the oil pump drive shaft and I didnt see it.............it broke , and I lost oil pressure AGAIN , only this time I caught it before it killed everything. Polished crank , sent rods to GRP for evaluation.........they replaced 2 rods because they were a little out of shape on the big end. And let me just say this.........GRP is a stand up company because they replaced those 2 rods at ZERO charge to me. Those rods had 14 runs on them at the time. So as you can see , my crank / cranks take a beating and come back for more......... ![]() |
Liked 307 Times in 103 Posts
if crank wasn't magnafluxed when ground, may have been cracked and then broke.
#4 main bad and others good sounds like crank was cracked and rubbing bearing before it broke, if look closely may see where #3 and # 5 main bearings have been rubbed some,most of the time when you have a few main bearings rubbed/wiped out the crank will be cracked and flexing. Was the radius left in crank when reground?If had 1/8 radius and it was cut less or square that weakens the crank also. When I tear into engine with broken oil pump,I check balance of rotating assembly,clearance between oil pump shaft and block and oil pump pick up/pan clearance. but there is chance since most bearings were OK that crank broke and vibration from that broke oil pump. Mike Taylor 3601, |
#5 | |
Mike Pearson 2485 SS |
#6 | |
Liked 30 Times in 17 Posts
Bill Koustenis |
Liked 1,830 Times in 415 Posts
It has been my experience that the vast majority of crankshafts that fail from fatigue fail either in front of #1 rod journal, or behind #8.
For an aftermarket crank, I strongly suggest Callies, I don't think you'll find anything better for Stock Eliminator or Super Stock.
Alan Roehrich 212A G/S |
Liked 358 Times in 83 Posts
You probably already know this, but just in case... Be sure to have the converter, front pump bushing and front pump checked (assuming the car uses an automatic trans) before you put the car back together. With the rearmost chunk of the crank wobbling around when the failure occurred, they may have gotten hurt.
A quick way to check for a crack on a forged crank is to hold it off the ground and tap it with a hammer. If it rings like a bell it's good. I it gives a thud sound it's cracked. If it's a cast crank you have mag them.
Never reuse a crank, especially in a racing motor, without magging it even if you are not grinding it or even if it did not blow up.
