Old 09-16-2015, 11:18 AM   #1
GregP
Default Re: Stock Elem Crankshafts??
Originally Posted by Alan Roehrich View Post
Yes. Callies. You just have to do the legwork. Or work with an engine builder or supplier who can and will.
I looked at Callies, they do offer a dragonslayer that would be great, its just not on the approved NHRA list. if there is a trick to this or something please P.M me. I realy wnt to buy the best parts for my engine so I dont have to worry about building a grenade. I used to work for a shop that built comp elem engines, but stock is a total different world from what I am use to.
GregP is offline   Reply With Quote
Old 09-16-2015, 11:48 AM   #2
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Not likely you will get the Dragonslayer approved but you should be able to get something nice added to the list. I have had two cranks put on the list. It take a bit of legwork, effort talking to Bruce as well as the people at Callies. Once you have all your ducks in a row it goes pretty fast.
Here is the NHRA form.
http://www.nhra.com/userfiles/file/A...val%20Form.pdf
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 09-16-2015, 12:08 PM   #3
GregP
Thanks for the info, I will start looking into this more.
Old 09-16-2015, 04:50 PM   #4
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
OK, why would you need a forged crank in a 305? I would imagine the RPM level would not need a forged unit? Some people are surprised that I used a real 396 block for my 396/325 as opposed to a sleeved 454. Plus it is only a 2 bolt main. Yes I do have steel crank in it, Motor has been up to 7300, but loses power over 6400 so I don't need to go there.Made over 100 passes on that motor. Is that the same deal with those 305's ?
Remember the sreet, musclecar car show days "I have a 4 bolt main block too"
Could I dare to say sometimes we can over engineer something when it does not need it.
My buddy has run Comp for years, and yea, 10,100 RPMs big difference from a Stocker motor. Checking Valve springs after every pass, tear the motor down during week, ect.
Will Lamprecht I/SA in progess 396/325
Old 09-16-2015, 08:59 PM   #5
nolongerracing
Liked 72 Times in 27 Posts
Wait a week or so... there will be a couple of 3.480 stroke cast cranks (1 Scat and 1 Eagle) added to the approved list.
nolongerracing is offline   Reply With Quote
Old 09-17-2015, 10:01 AM   #6
GregP
What about forged, they are plenty of cast out there..
Old 09-17-2015, 09:17 PM   #7
nolongerracing
400 HP, 7000 RPM, why would you put a heavier forged crank in a 305 stocker. Waste your money where you want to. I've seen many 350 SuperStock engines run a 30 year old cast crank 600 HP and 8500 RPM.
Old 09-17-2015, 09:58 AM   #8
GregP
Not really sure it is a absolutly needed item but I hate to destroy a engine by cutting corners. I am sure it would hold up but I had just rather not chance it.
