Old 09-18-2015, 08:57 AM   #1
James Perrone
Liked 1,826 Times in 426 Posts
Default Re: Stock Elem Crankshafts??
if it didn't come with a steel crank you can not use one.. good luck with that
james perrone 1290 STK
Old 09-18-2015, 09:05 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
James, why do you say that? I see no ruling that states that, and there are lots of instances of engines that were not produced with forged or cast cranks running either.
Old 09-19-2015, 08:49 AM   #3
GregP
well said, also with that being said I am hearing several guys running this set up that I am building even using cast iron intake manifold when the engine original came with aluminum. I had a reputable carb guy tell me he has found early model rochester carbs that are accepted for the 85 305. it seems to me that there are a few pieces they are accepting that were not absolutely stock.
GregP is offline   Reply With Quote
