Old 10-05-2015, 11:35 AM   #1
Dale Hulquist
Liked 351 Times in 76 Posts
Default 1967 Camaro Frt Susp
Does anyone use a rubber or nylon snubber under upper control arm to limit travel, or any suggestions ?
Dale Hulquist is online now   Reply With Quote
Old 10-05-2015, 12:02 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: 1967 Camaro Frt Susp
I use a poly snubber similar to a traction bar snubber. I have it mounted to a 5/8 stud so I can adjust it up and down. I have a 5/8 nut welded to the upper a arm then use a jam nut on the top. I have the same snubber on the lower a arm as well
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 10-05-2015, 09:28 PM   #3
Dale Hulquist
Thanks for the reply Mike, your idea sounds a lot better than mine, I wasn't thinking about the ease of adjustability, where did you get the snubbers from? Thanks Dale H
Old 10-06-2015, 02:40 AM   #4
GTX JOHN
Liked 2,486 Times in 697 Posts
Summit sell a large number of different designs........Many easy to cut for
your need application.
John Irving
741 Stock
741 Super Stock
