Old 11-23-2007, 08:57 PM   #1
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Lt 1 Motor Lift Plate
looking for a motor plate designed to pull a LT 1 out of a 1997 Camaro thanks
DIAPERMAN is offline   Reply With Quote
Old 11-24-2007, 11:22 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Lt 1 Motor Lift Plate
Look at ebay item 230195365220---Will this work???? Comp 387
Old 11-24-2007, 12:11 PM   #3
Chuck Norton
Liked 89 Times in 19 Posts
That e-bay item is for an LS1. It won't work on an LT1. Do a search for "Happy Hooker." In addition to a possible link to some good-time girls, you'll eventually find a reference to a device that bolts to the fuel rail bosses on top of the LT1 manifold. I've never used one of those myself but I've been told that they work very well.
Good luck
Chuck Norton is offline   Reply With Quote
Old 11-24-2007, 12:20 PM   #4
Chuck Norton
On second thought, before this thread deteriorates entirely, check the following URL:
http://tpis.com/index.php?module=cat...y=Happy+Hooker
Old 11-24-2007, 06:11 PM   #5
FED 387
Thumbs up Re: Lt 1 Motor Lift Plate
Try TPI Specialties
Website tpis.com
Address 4255 creek rd
Chaska, MN 55318
Tel 952-448-6021
Fax 952-448-7230
Lotsa nea t stuff there---Sell the engine plate for $49.95
Also on ebay item 270135625201 looks just like the other item I told you about but with a few more holes in it---Comp 387
Old 11-24-2007, 08:19 PM   #6
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I used a home made setup. A square piece of stock about 1" by 1" and wider than the engine, crosswise. 4 chains attached to the ends and I bolted the chains to the 4 corner exhaust header holes. I use this same setup on any engine with a real tall t-ram style intake. I attached it as tight to my engine hoist as I could get it and also added an extension to my hoist. Had to add weight to the back of the hoist to act as a counterweight. The holes in the intake for the fuel rails are very small.....The plate would be easier but I used what I had and it worked fine. I removed all the stuff on the front of the engine.....water pump - housing, dist. cap and balancer.
Rich Biebel
S/C 1479
Stock 147R
Rich Biebel is online now   Reply With Quote
Old 11-26-2007, 09:29 AM   #7
DIAPERMAN
Talking Re: Lt 1 Motor Lift Plate
Thanks guys this should help
