Liked 99 Times in 60 Posts
Racers,
I will be changing from a 6.0 gear to a 5.86 gear. Originally I bought the 6.0 US gear from Strange then sent it for Cryo. treatment. The 6.0 only has 10 runs yet it looks new. Do we have any up-to-date feedback in ref to gear brands? Is the US gear still a good choice? Other valid choices? Any update about Richmond gears?
Larry Woodfin 471W |
Liked 1,934 Times in 581 Posts
You might think about going to a taller tire if possible. That's a pretty small gear change. A 2 inch larger roll out would accomplish the same result. I assume you are going to a 350 combo now. I ran my 350 with a 6.17 and a 101 roll out Radial tire with good results. I put a 5.86 gear in the car now. I had less engine breakage with the 6.17. I guess that put less strain on parts even though the trap RPM was a bit higher.
Mike Pearson 2485 SS |
Liked 780 Times in 194 Posts
Less gear and smaller diameter tire should accelerate a bit quicker.
Dwight,
that is also my thought.
I am curious about the Richmond gear quality. In earlier post some comments were made about Richmond "not what it once was"
Do we have any feedback about Motive Gear or US/Strange Gear?
Part of my question is answered. Motive does not offer a 9310 material gear.
Liked 1,583 Times in 582 Posts
Liked 71 Times in 38 Posts
New Gleason gears are very expensive,however you can find them "lightly used" from the NASCAR teams.I bought a set that had already been lightened,REM coated and run in.I believe Gleason makes a drag race specific gear set if you want to spend the money.
I expect a 5.86 set is not the usual NASCAR ratio.
Yes they are; you can find Gleason 5.67, 5.83, 6.14 and 6.50 gears in Ebay all the time.
As a matter of fact, yesterday they had a set of used Gleason 5.86 gears that sold for $145.00. They were lightened and REM coated. Look also for Visteon gears; they are made for NASCAR teams. |
