Old 11-02-2015, 03:02 PM   #1
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Re: 302 ford intake advise
Originally Posted by 68Coupe View Post
Rory
was wondering if you could give more specs on the cam you ran in your 331
Sure, Comp Cams FS 290B-6, Int. lift .576", Exh. .570" 106 lobe sep.,
Int. dur @ .050 255, exh.266.
After 5 years, the cam and lifters look great, so they will be going back in a new block.
NHRA 6390 STK
M/S 85 Mustang
Old 11-03-2015, 10:21 AM   #2
Lou Jeffery
I ran a Victor jr. on my 270 hp 302 crate motor and it ran pretty good. I did have a few drivability issues like stumbly running in the water and staging. I installed a Performer RPM air gap dual plane and it cured any issue I had plus picked up about five hundredths overall and much easier to drive. This combo uses a .498 lift hydraulic roller and a GT40P head. Went 11.40s at 111mph @2930 lbs.
Lou Jeffery is offline   Reply With Quote
Old 11-04-2015, 12:48 AM   #3
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
On the Dyno, My Crate Motor 302/270 liked the Victor JR w/ a 1" spacer. and Although the 750 made a touch more peak HP, a smaller carb made better average TQ and HP throughout the range
Here is a fun 331 built at the local racing engine shop. With the exception of the AFR's , a budget build, stock unfilled block, Cast scat crank , scat rods etc.. Victor JR, and Dave insisted on the Demon carb..
Enjoy,
https://www.youtube.com/channel/UC69...revJlEXyJH9k9w
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 11-06-2015, 02:38 AM   #4
casrak7
Liked 3 Times in 2 Posts
can you give me details of this crate motor? auto or stick ? and how much converter and what trans if auto? thanks!!
casrak7 is offline   Reply With Quote
