Old 12-01-2015, 01:07 PM   #1
Jim Caughlin
Liked 801 Times in 244 Posts
Default Re: Lightened ring gear, riffle drilled and star flanged axl
I did do back to back test on steel (13#) vs alum (10#) driveshafts, zero improvement. In my case, I have a pretty low HP high RPM combination so if anyone would improve, I would have thought it would have been my car.I also have all the lightweight rearend parts. I really don't think there is any performance difference in any of it. That being said, if I were starting over, I would buy the lightweight stuff anyway. It just seems that intuitively it is better to have the lightest rotating parts regardless. At least it gives you the opportunity to run lighter or put sprung ballast in the car if needed.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 12-01-2015, 01:19 PM   #2
Ed Wright
Ed Wright's Avatar
Diameter has a big effect. Ten lbs flywheel weight has more effect than ten lbs crankshaft or driveshaft weight. Axles? I can not imagine seeing anything. Another one of those "it can't hurt" deals.
Ed Wright 4156 SS/JA
Old 12-01-2015, 01:48 PM   #3
Jim Caughlin
On the subject of flywheel weight, reducing clutch and flywheel weight and diameter made HUGE improvements in my car. I would have to think that alum torque converters would have the same effect for the auto trans guys.
Jim Caughlin
SS 6019
Old 12-01-2015, 02:10 PM   #4
Ed Wright
Ed Wright's Avatar
Jim, I have heard mixed reviews about those. I'm told by a gentleman that runs a fast hood scoop SS car they can be worth as much as a tenths. A friend with a good, conventional SS car he saw nothing, but a much lighter pocket book. Might be related to RPM range?
I can't afford the five grand I was told they cost anyway.
Old 12-01-2015, 07:25 PM   #5
james schaechter
Liked 1,428 Times in 296 Posts
I think that the Benefit would be so small. It would be hard to measure. There are a lot of good cars out there without any of this stuff.That being said, I think if you keep picking away at the areas mentioned, to lighten the car in all areas you can, especially unsprung weight, it can make a difference. It can make a good car a great car! Hard to measure, but sometimes that is the difference between qualifying or not at INDY.
I can tell you that our car has been one of these efforts. We have worked over the years to lighten up things we could afford. It maybe isn't quicker or faster in good conditions, but we can move weight around better and the car is more tune able to be good even in rough track conditions. If you think you can pick one of these things and make the car fly, you will be disappointed. If you are scratching out every Hundreth to be competitive, it might be worth it.
I don't think a bracket car would be worth doing it for the cost involved.
James Schaechter 3163 STK
Old 12-01-2015, 09:29 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,916 Times in 574 Posts
Jim Caughlin
SS 6019
When I ran a stick in my car 7 lbs off the flywheel was worth 2 tents.
Mike Pearson 2485 SS
Old 12-01-2015, 09:47 PM   #7
james schaechter
Wow what was the total weight before for your clutch assembly?,
Old 12-02-2015, 12:12 PM   #8
Mike Pearson
That was going from a 20 lb steel flywheel to a 13 lb aluminum with a steel face. All old school clutch stuff from Ram.
Old 12-01-2015, 10:29 PM   #9
Ed Wright
Ed Wright's Avatar
Mike, that is a large enough radius to see something. An axle? Not so much.
Old 12-02-2015, 12:15 PM   #10
Mike Pearson
I put a lightened ring gear in my Dana and did not see any ET reduction. Changed the ratio at the same time so not a real good test. All of my driveline stuff is real heavy. A hold over from my stick days.
