Liked 275 Times in 76 Posts
Phil,
I just spoke to Bob Blackwell our D5 tech director, and you will need to submit this for a rule change. Bob did not have to think very long before he answered, so it is a no. It's not a big deal to get the ball rolling to at least get this reviewed. I pointed out the clarification on the auto trans so that is your ringer. Why can an auto car that came with a 2 speed run a 3 speed, but a stick car that came with a 3 speed not be able to use a readily available 4 speed? The sooner you get something submitted the better off you will be. The first G-Force I bought was from Jim Voth, it was a 5 speed as I am allowed to run one, but Jim could not, so he had removed the gear for 5th to be legal. It was another neutral, I do not remember if he did anything with the shifter as that was not part of the purchase. So you will be stuck with something like that, but worse and some not very ideal gear ratio combinations with a 3 speed. I hope I did not muddy the water for you. Sean
Liked 880 Times in 311 Posts
At one time I think there was an allowance for a car that was offered with overdrive.
Like, the three speed with overdrive option is allowed a 4 speed. Or was it just talked about? I think Dwight or someone that still has a memory.might be able to help my memory on that one.
Adger Smith (Former SS) Last edited by Adger Smith; 12-08-2015 at 02:22 PM. Reason: sp |
Liked 783 Times in 195 Posts
Adger, that was just talked about. That came about because supposedly you could take a BW T-85 three speed with overdrive and with some case modifications install a T-10 separator plate and tail housing with 4-speed guts. I don't know for a fact it was ever done, but some old Ford guys claimed it and argued that it should be legal. It falls into all that stuff about what do you do with a 5-speed od manual and 4-speed od automatic: Is it a 5 speed so you can run a Liberty or Doug Nash or Jerico 5-speed. Is it a 4-speed so you could build a 4-speed automatic?
Wait for the rule book. After all, what passes tech is what is legal, not what the factories built.
