Old 12-16-2015, 05:15 PM   #2
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
Default Re: how to ID this converter?
Hi, the only info I could give you on those stampings is that it has an Opel 073 style stator in it, the HF would designate high flow, the LS would designate low stall. Without opening it you cannot tell the pump blade angle or clearances. I would guess it would have a positive pump angle with a low stall stator, so it would probably be a low stall piece for an 8". Hope this helps a little.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
