Old 12-21-2015, 12:35 PM   #4
Eman
Liked 133 Times in 76 Posts
Default Re: TH350 Strength
Rubber mount for sure. Case will crack near cooler lines if stressed, only case I cracked was with a frt. motor plate and only a trans mount and the case was trimmed of tabs which weakened it. If you pull the pump and the input shaft it's easy to ck for the 36 element sprag if you're concerned. I ran with only a hardened race for years with no failures. Be gentle with 2nd gear and you'll have no problems. Start burnout in 2nd and shift to 3rd quickly. Don't ever come out of burnout in 2nd and shock it by having the tires grab.
