Old 01-07-2016, 09:53 AM   #11
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: 305 crankshaft
267,305.350 all are same crank,just different balance,all same just 305 has more weight took out of counterweight and 267 has more removed,some have more and deeper holes,some have couple v shaped notches in counterweights and deeper drilled holes.
Mike Taylor 3601
Old 01-07-2016, 10:32 AM   #12
Signman
Liked 269 Times in 99 Posts
There are cranks on the accepted list be sure to call the manufacturer to be sure rod journals are not drilled.
Old 01-07-2016, 11:40 AM   #13
REGGIE WINKLES
Liked 39 Times in 9 Posts
I prefer the 70 350 LT-1 steel crank for my 305 stick application. Never any failures,crank has been in use over 20 years.
Reggie Winkles 2650/Stock
REGGIE WINKLES is offline   Reply With Quote
Old 01-07-2016, 01:41 PM   #14
Liked 5,125 Times in 1,953 Posts
For those who haven't been following along with this build:
Guys, this is a 2bbl, automatic application.
Mr Money, If you want specific answers here, then you need to ask specific questions .
Old 01-07-2016, 02:28 PM   #15
jmoneyfoot
Liked 9 Times in 5 Posts
This is a 145hp 305 2bbl not a ton of power I just am wondering if a stock 305 crank will hold up or if I should use a steel 350 crank. Seems like everyone is trying to get the lightest crank possible. Im wanting to build a very compeditive R/SA but are finding out racers neet me dont like to talk about there combinations. Will a stock 305 crank go 7500+rpm?
jmoneyfoot is offline   Reply With Quote
Old 01-07-2016, 02:49 PM   #16
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
It will hold up well. I have run cast cranks in super stock engines that rev to 8500 rpm with no failures. You might also think about using the factory 305 rods. They are lighter than the aftermarket rods and would be plenty strong for the application you are talking about. Resize and some new high strength bolts.
Mike Pearson 2485 SS
Old 01-07-2016, 05:13 PM   #17
kansas stocker
Liked 249 Times in 48 Posts
I'll be more than a little shocked if your 305 2 barrel combination is a 7500+ package. If it is you need to be asking lots of lifter and spring questions.
Pete
kansas stocker is offline   Reply With Quote
Old 01-07-2016, 05:13 PM   #18
Signman
Removing weight from the center of rotation is not as important as reducing weight of components at the outside of rotation and that stop and start. Look at ways to reduce friction and windage losses.
Always listen to Billy!
Old 01-07-2016, 07:27 PM   #19
MR DERBY CITY
Liked 7,940 Times in 1,520 Posts
Pete
X2 Mr. Kansas.....if it turns 7500 then it is BAD AZZ
