#11 |
Liked 308 Times in 103 Posts
267,305.350 all are same crank,just different balance,all same just 305 has more weight took out of counterweight and 267 has more removed,some have more and deeper holes,some have couple v shaped notches in counterweights and deeper drilled holes.
Mike Taylor 3601 |
#12 |
Liked 269 Times in 99 Posts
There are cranks on the accepted list be sure to call the manufacturer to be sure rod journals are not drilled.
#13 |
Liked 39 Times in 9 Posts
I prefer the 70 350 LT-1 steel crank for my 305 stick application. Never any failures,crank has been in use over 20 years.
Reggie Winkles 2650/Stock |
#14 |
For those who haven't been following along with this build:
Guys, this is a 2bbl, automatic application. Mr Money, If you want specific answers here, then you need to ask specific questions .
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 01-07-2016 at 01:45 PM. |
#15 |
Liked 9 Times in 5 Posts
This is a 145hp 305 2bbl not a ton of power I just am wondering if a stock 305 crank will hold up or if I should use a steel 350 crank. Seems like everyone is trying to get the lightest crank possible. Im wanting to build a very compeditive R/SA but are finding out racers neet me dont like to talk about there combinations. Will a stock 305 crank go 7500+rpm?
#16 | |
Liked 1,943 Times in 584 Posts
Mike Pearson 2485 SS |
#17 |
Liked 249 Times in 48 Posts
I'll be more than a little shocked if your 305 2 barrel combination is a 7500+ package. If it is you need to be asking lots of lifter and spring questions.
Pete |
#18 |
Removing weight from the center of rotation is not as important as reducing weight of components at the outside of rotation and that stop and start. Look at ways to reduce friction and windage losses.
Always listen to Billy!
#19 |
Liked 8,014 Times in 1,526 Posts
