Old 01-12-2016, 03:41 PM   #7
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Pure Stock Suspension
Originally Posted by rocketolds400 View Post
I was kind of confused with this as well. Was toying with the idea of building a Pure Stocker, and wasn't sure how restricted the suspension actually is.
The rulebook states:
"SUSPENSION: Must be OEM per horsepower claimed. Any stock type shocks permitted. No other suspension changes or additions permitted."
I almost read that as saying you can change the shocks but no other changes are permitted. Obviously can't add things, but can't swap either? So you can't change control arms to aftermarket even if they bolt in the stock location and are stock style? Can't box/reinforce uppers and lowers on a GM A/B/G body?
YES .. HD Bolt On rear control arms replacement is fine.
Boxing is fine since it makes the stock arms stronger.
Hardened Bushings replacement is fine.
Does not change the geometry.
So long as it does not change the suspension design.
Which most don't. Safety first is good..!
My car uses 3/4" longer control arms to fit larger slicks.
Dan
