Old 01-18-2016, 10:09 PM   #11
George Wright
George Wright's Avatar
Liked 408 Times in 35 Posts
Default Re: Lapping piston rings
I had this tool made up about 25 years ago. It is for a 4.060 bore. On one side there is a dish cut in it that allows you to hold a ring inside of it. The ridge is about .025 tall so that the ring is exposed. I can then use this fixture to sand down the ring on a piece of fine paper taped to a piece of glass. The other side of this ring fixture is used for squaring rings in bores when checking / setting the ring end gaps.
ID:	32250   Click image for larger version
George Wright https://9500rpm.com
George Wright is offline   Reply With Quote
