Old 01-19-2016, 04:03 PM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Gasket recommendation
My 427 BBC valve covers leak vacuum at the curves. These are steel Moroso covers with thick cork gaskets. There are many to chose from but which will seal the best? I think the leak is between the gasket and the head not the gasket and the cover. I usually use the nasty 3M yellow weather stripping to glue the gasket to the cover.
Ron Gusack is offline   Reply With Quote
Old 01-20-2016, 10:06 AM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: Gasket recommendation
I like the thick cork with steel in between the layers, you may contact Allen Mackin on here Almack he makes a neat deal to go on the covers that will help seal them up.
Mike Taylor 3601
Old 01-20-2016, 12:57 PM   #3
Ron Gusack
Ron Gusack's Avatar
Mike Taylor 3601
Thank you Mike
Old 01-21-2016, 05:53 PM   #4
65signet
Liked 49 Times in 22 Posts
I have had real good luck with Edelbrock gaskets, same pair and pulled the covers off multiple times and no leaks.
65signet is offline   Reply With Quote
Old 01-21-2016, 09:36 PM   #5
pmrphil
Liked 348 Times in 152 Posts
With the stamped valve covers I've always had better sealing using load spreaders, never needed any specific gasket after that.
Phil Molski
PMR Performance
S/C 1623
Old 01-22-2016, 12:11 PM   #6
Mike Taylor 3601
Almack has best deal to stiffen valve cover rail.
Mike Taylor 3601
Old 01-24-2016, 06:57 PM   #7
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
www.superformanceproducts.com
These are the best gaskets I have ever used.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 01-25-2016, 06:23 PM   #8
1969chevss
I use SCE gaskets on my big block and small block chevy's. part # for the big block i have used 213076 laminated 1/4" cork or 213077 molded rubber both have worked great
1969chevss is offline   Reply With Quote
