Old 12-03-2007, 12:06 AM   #1
will prater
Liked 7 Times in 4 Posts
Default Re: NHRA rod acceptance
Originally Posted by gmonde View Post
i am in the process of doing the same,contact nhra tech, if you have a rod your going to use you will have to send them one so they can mesure and weigh it,keep us posted on how you make out gmonde
What bothers me about this is the rod supplier thought I should go ahead and purchase a set then submit it because they only had a few sets left and are not going to make up anymore 383 length rods with the .990 pin diameter. I didn't want to buy a couple of sets only to find out NHRA would not accept them. The rods are supposed to be very close to the listed stock weight. I guess I will call NHRA tech tomorrow and see what I need to dol Thanks
will prater is offline   Reply With Quote
Old 12-03-2007, 12:49 AM   #2
Mark Tallent
Angry Re: NHRA rod acceptance
Will; The rod supplier knows that the market is very limited for racers that will buy the rod and they don't really care if NHRA accepts thier rod, If I were in thier position I'd make you buy a set and "YOU" can supply them with the sample. This seems to be the problem with NHRA they don't care what happens with S/SS and the suppliers know it so they act accordingly, Have you won "Class" lately? that's all you need to know what's going on.
Mark Tallent 7724 STK, SS
Mark Tallent is offline   Reply With Quote
Old 12-03-2007, 01:34 AM   #3
Having just been through the approval process for parts, I suggest you contact Len Imbrogno, Wesley Roberson, and probably Bob Lang. You should also be aware that the manufacturer of the component must submit the part and the supporting documentation. And yes, the manufacturer will almost surely require you to buy the part they submit. Be prepared to spend money, make phone calls, send emails, be frustrated, and wait.
