Old 02-02-2016, 08:57 AM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: BBC "undercut" oil pump drive shaft
Lathe.
Old 02-02-2016, 10:40 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Dwight,
The question has been raised about what affect cutting the shaft will have on heat treatment.
As we understand, modifying an oil pump driveshaft is not to be taken lightly considering the potential consequences.
Any thoughts about the heat treat issue.
Larry Woodfin 471W
Old 02-02-2016, 01:51 PM   #3
Dwight Southerland
Treat it again. If it is only surface treated (so you would machine the hardened surface away), then heat it up until it is red with a torch and dip it in a bucket of old engine oil. Otherwise, buy a shaft that is higher quality steel to start with. The original OEM shafts that were necked down were for the 400. I believe they used 1040 alloy rod that was quenched and then austempered, which would harden the material all the way through. Simple process if you feel it is worth it. Personally, I would not be concerned with the strength after machining.
Old 02-02-2016, 02:55 PM   #4
Dan Timberlake
How much material must be removed?
Dan Timberlake is offline   Reply With Quote
Old 02-02-2016, 04:02 PM   #5
Dragsinger
I am mocking this up again for another look and will post some photos soon.
Larry Woodfin 471W
Old 02-02-2016, 09:27 PM   #6
Dragsinger
as Paul Harvey said, "now, the rest of the story"
In hindsight, I did not have a problem. The block is a Brodix SBC with raised deck and raised cam. Because of the raised cam, Brodix has it worked out to install a .350" thick spacer between the rear main cap and oil pump then drive it with a BBC driveshaft.
My perceived problem was because when mocking up and checking on the bench I used a rear main cap from a factory SBC block. At first, I did not realize Brodix had made allowances and everything was already as needed.
The oil pan was just hang on the Brodix block for protection and it came to me in a vision to actually check the block and cap that goes with the buildup !
Once I slipped the pan off I immediately realized the Brodix rear main cap driveshaft hole was about .250" larger than a factory cap.
ID:	32298   Click image for larger version
Larry Woodfin 471W
Old 02-03-2016, 12:35 AM   #7
Dragsinger
FYI, the new Melling Shark Tooth oil pump.
Also, it always interest me to see things in a view not usually seen. Note the oil pump and driveshaft angle.
ID:	32303   Click image for larger version
ID:	32304   Click image for larger version
Larry Woodfin 471W
