Liked 6 Times in 6 Posts
John had some exp with 4412 guage legal,used vdl,pro sys and box stock jetting was between 71 to 73 pv was 6.5 to 8.5 both sideways and forward mount , manifold and spacer made a diff.Not so much as to who did carb.
The 4412s is the best of the original castings. This was the number on the first run of the 4412's. Every time Holley made another run the castings seemed to flow a little less. I don't know about the newer 500's. Never had a chance to work with them. I suppose the rules cover them but what about the 650 Holley two barrel. they really work and I have found them on Ebay now and again. Bob Oliver is the best I have worked with on any Holley 2 or 4 barrel. A few more things. Use the 35cc accelerator pump. When you use the 50 cc pump it fattens the engine up so much it takes the whole straightaway to clean it up. Use the anti pull over shooter. EVERY circuit in the 4412 is trying to work at speed. Main circuit, idle, transition slot and the shooter. Try a 2.5 power valve, it will give you a high speed lean out. If you are doing your own carb I hope this helps. Happy motoring!
Liked 333 Times in 180 Posts
John-- the 4412bkx has had the choke air horn removed, uses different down leg boosters and has had the screw in air bleeds repositioned further towards the side of the carb to improve air flow--- if you can use a 6425 Holley 2 bbl carb they are rated @ 650 CFM not 500 like the other 2 carbs-- you will definitely need to utilize a anti pull over nozzle make sure you double stack the washers and use a washer top & bottom on the nozzle might need to use a solid screw instead of the hollow one-- Holley makes a anti pull over kit don't remember the part number but I'll get back to you on that- you might have to work on the accelerator pump area too-- I use a small Honda valve cover grommet sanded down to about 3/16 inch and use JB Weld to epoxy it to the pump gasket to hold it in place then fit the return spring over it-- you only need that pump for the first shot about 1/3 then let the carb do its thing--- probably plug the power valve up too--- it's all trial and error
Sorry there --is no kit just the nozzles and they come in about 6-8 different sizes-you might also need to drill a small hole in the nozzle to act as a vacuum break---You might need to change float bowls too if you have the one with the flapper in it---you will need to get one that has a check ball in the bottom of where the accelerator pump mounts instead of the bowl that utilizes the rubber flapper--- that rubber flapper tends to vibrate and can actually act as a accelerator pump by allowing fuel to be pumped thru the circuit when you do not want fuel coming out of those nozzles.
Liked 6 Times in 2 Posts
You guys are incredible ! Thanks for the help ! I'll let you know what's going on with this !..John
John Lang 365 STK, SS |
The vdl came with a 35cc pump, the stock 4412 50cc, the baker was 50.cc never had a problem with it being too rich off the turns. these were guage legal with choke tower.Some had a tiny bleed hole in the metering block above the jets for pullover.Some were run without pv and jetted around 76.
