Old 02-13-2016, 09:14 AM   #1
sox
Liked 13 Times in 8 Posts
Default Turbo 400 Question
Im putting together a Street Car and it has a 400 Turbo Trans in it.It takes about 20 seconds to go in gear.Once engaged it shifts fine.I pulled the pan off last night and the filter was slapping around.After some research,they say its suppose to be that way.I also seen where a guy put a spring on the shaft where it mounts to tighten it up from slapping around.Any suggestions about this and could that cause the trans not to engage right away.
sox is offline   Reply With Quote
Old 02-13-2016, 10:52 AM   #2
Liked 1,952 Times in 439 Posts
Default Re: Turbo 400 Question
Usual causes:
Low fluid
Clogged filter
Air leak at either end of the filter tube
Excessive converter drain back
Hard lip seals
A spring to hold the filter down against the head of the filter bolt won't hurt, but it is not necessary.
Old 02-13-2016, 12:38 PM   #3
sox
It does leak thru the seal.I did talk to a guy who suggested seal conditioner from GM.
Old 02-13-2016, 12:48 PM   #4
Seal conditioner is useless. It just swells the seals temporarily. You can do that with a pint of DOT 3 brake fluid. It will probably do nothing at all. It may just hasten the need for an overhaul.
The lip seals I referred to are inside.
Warm the car up to operating temperature, get it to move, then put it in park on a level surface and check the fluid level, make sure that the fluid level is right on the "full hot" mark. Then let the car sit for a day or two. Check the fluid before you start it. Then start the car and immediately check the fluid level. Note the differences.
Old 02-15-2016, 11:34 AM   #5
Jim Kaekel
Liked 537 Times in 111 Posts
Alan is correct, lip seals are probaly old and hardened up, causing a ton of oil pressure leakage. Time for a rebuild. I presume you did change the oil filter when you removed the pan as the stock style filter is easily clogged? If it's clogged, you'll hear a "screaming" noise when you start the engine caused by the pump and converter starving for fluid.
Jim Kaekel 3836 STK
Old 02-16-2016, 08:58 AM   #6
sox
Replaced the Filter and New Fluid and still is lagging going into gear.Looks like a Rebuild is in order.Thanks Guys for the info..
