Old 02-13-2016, 10:25 AM   #1
curtis hieb
curtis hieb's Avatar
Liked 9 Times in 8 Posts
Default 2004 Fleetwood Excursion
I bought this motorhome in 2009 I have kept it in warehouse when not in use it had 26000 miles when I bought it,now it has 53000 miles runs and drives great mileage on the worst day was 7.5 on good day around 9 mpg. I replaced the rear tires 2 years ago and also replaced the 6 batteries. It has air ride suspension so it just floats down the road the diesel pushers drive so much better then the front engine units I think mainly because of the weight. It has to be pretty windy before you cant drive comfortably down the road. It has a 10000 lb hitch so you can pull any kind of trailer. I used to pull 28 ft enclosed trailer with it and not even know it was behind you. This Fleetwood excursion is built on freightliner chassis which is most preferred for service and they will not heat when pulled hard in mountains. The engine is a 350 hp Cummins with Allison 6 speed trans. It has 2 AC and 2 furnaces also satellite tv if there is anything else you would like to know give me a call. 605-730-0443 View photos https://imgur.com/a/aG8lF asking 65000.00
curtis hieb is offline   Reply With Quote
Search this Thread:
Advanced Search
