Old 12-04-2007, 10:52 PM   #11
Dennis Paz
Liked 5 Times in 3 Posts
Cool Re: 2008 rules changes!
What exactly is a three speed poweglide??
Dennis Paz is offline   Reply With Quote
Old 12-04-2007, 10:58 PM   #12
7820
7820's Avatar
Default Re: 2008 rules changes!
Two speed with overdrive. LOL!!! GM must have built thousands of them...right?? LOL!
7820 is offline   Reply With Quote
Old 12-04-2007, 11:11 PM   #13
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
now these rules pretain to all divisions? i havent seen any thing on the nhra site the one that intrest me the most is the accusump/any valve job angle for stock gmonde
Old 12-05-2007, 01:01 AM   #14
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
I found out what the TDC pointer rule is. If you have this style of pointer, they must be pinned as apparantly the pointer pin has been known to fall out.
Disclaimer: Just using this brand as an example for a picture only.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 12-05-2007, 08:51 AM   #15
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The rules change on heads is going to cost you a good deal of time and money. All seats and any valve job? Wow....Stock has had the same valvejob rules since the beginning. Now they throw that out the window too......And you can add an oil accumulator....that is a good rule. Stock is fading away.......they should change the name to Almost SuperStock. I'm glad I'm out of it.
Rich Biebel
S/C 1479
Stock 147R
Old 12-05-2007, 10:33 AM   #16
SSDiv6
Why does anyone need an accumulator? If they need one then they have an issue with oil pressure, then they have not done their homework on their oil pan. You can buy a stock looking oil pan from many manufacturers with trap doors and/or baffles that will prevent oil pressure loss when you slam on the brakes or wheelstand. Milodon, Canton and Kevko make these type of pans. Many will make the case that their oil pressure drops during decceleration and the reason why the need the accumulator, but the reality is that it allows for a lower oil level in the oil pan, reducing windage and freeing up horsepower.
Old 12-05-2007, 11:56 AM   #17
Ray Menard
Ray Menard's Avatar
Oil Accumulator...I use mine mainly for start-up. Since I drain the water between races, it doesn't get started until just before the next event. The accumulator puts 70# of oil pressure into the motor before starting.
Also, since my motor goes through the lights at 9,700 RPM, I just get a little better feeling knowing there is plenty of oil available, if needed.
Ray Menard
SS/CS (SS/DM & SS/EM)
#7386
Ray Menard is offline   Reply With Quote
Old 12-05-2007, 12:30 PM   #18
SSDiv6
Ray...I do not see a problem with a Super Stock car using the accumulator, specially yours with a Comp style engine...however, we are talking about Stock Eliminator cars.
Old 12-05-2007, 01:27 PM   #19
Don Fardie
Don Fardie's Avatar
I find it kinda bizarre that the 08 Rule Changes are only posted on the Division 5 site and no where else, but a big thanks to NHRA for letting us know about Ashley Force?s engagement?????.whatever!
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
Old 12-05-2007, 01:40 PM   #20
Rusty Davenport
Liked 101 Times in 27 Posts
Question Re: 2008 rules changes!
Can somebody help me with what does "pinned" mean on the pointer ?????????
Rusty Davenport is offline   Reply With Quote
