#11 |
Liked 5 Times in 3 Posts
What exactly is a three speed poweglide??
#12 |
Two speed with overdrive. LOL!!! GM must have built thousands of them...right?? LOL!
#13 |
Liked 165 Times in 59 Posts
now these rules pretain to all divisions? i havent seen any thing on the nhra site the one that intrest me the most is the accusump/any valve job angle for stock gmonde
#14 |
Liked 510 Times in 117 Posts
I found out what the TDC pointer rule is. If you have this style of pointer, they must be pinned as apparantly the pointer pin has been known to fall out.
![]() Disclaimer: Just using this brand as an example for a picture only.
68 Chevy11 327 F/S |
#15 |
Liked 544 Times in 213 Posts
The rules change on heads is going to cost you a good deal of time and money. All seats and any valve job? Wow....Stock has had the same valvejob rules since the beginning. Now they throw that out the window too......And you can add an oil accumulator....that is a good rule. Stock is fading away.......they should change the name to Almost SuperStock. I'm glad I'm out of it.
#16 | |
#17 |
Oil Accumulator...I use mine mainly for start-up. Since I drain the water between races, it doesn't get started until just before the next event. The accumulator puts 70# of oil pressure into the motor before starting.
Also, since my motor goes through the lights at 9,700 RPM, I just get a little better feeling knowing there is plenty of oil available, if needed.
Ray Menard SS/CS (SS/DM & SS/EM) #7386 |
#18 | |
#19 |
I find it kinda bizarre that the 08 Rule Changes are only posted on the Division 5 site and no where else, but a big thanks to NHRA for letting us know about Ashley Force?s engagement?????.whatever!
Don Fardie 1582 F/S B/G |
#20 |
Liked 101 Times in 27 Posts
Can somebody help me with what does "pinned" mean on the pointer ?????????
