#21 | |
Liked 544 Times in 213 Posts
#22 |
What I don't understand is that if these rules are meant to "reduce failures" then why they do not allow roller rockers or even pushrod guide plates. Neither will give a distinct performance improvement, but would reduce failures at one of the weakest points on a stocker engine. Both are legal per IHRA rules. This is assuming that this list of rule revisions is accurate and complete.
#23 |
Liked 2 Times in 1 Post
How many, if any, of these pointers have fallen out? Just currious; It must have been alot, and they must have caused flat tires, or the NHRA wouldn't even notice them. Is someone trying to sell drill bits and pins now, or what?
#24 |
Liked 883 Times in 237 Posts
Come on Don! everybody needs to know everything "Force" , just ask any NHRA exec. LOL. ......We can be thankful at least Rob Park was thinking about giving his racers a heads up on the changes. .......... I dont know about timing pointers, but I've seen a lot of other junk laying on the track at the end of the day!! ................some of these rules are certainly "interesting" ,but requiring stacks on permantly mounted generators is one that makes sense and is way over due. .....Last year a tailgater died at a Penn State game due to carbon monoxide. ........... Think about how close we are pitted together at some races,and it amazing it has'nt happened to one of us. .....I know I always check my CO detector in the motorhome to make sure it's functional. .............As far as the valve job rule goes , I'm glad I did'nt freshen my heads yet!. ..........Tom
#25 |
Liked 4 Times in 2 Posts
Im using a small Honda generator that I carry and set behind our open trailer... def not building a stack if I head to an NHRA event.
Lee Norton - N229 STK IHRA H/FIA - NHRA O/SA RacerTees.com |
#26 | |
Liked 50 Times in 14 Posts
Do these companies make good baffled oil pans for Buick 350's? And every other combination?
Isaac Zane STK 1237 J/SA Buick Apollo Patriot Guard Rider DOOF 43 |
#27 |
Liked 316 Times in 67 Posts
They anguish for months over buttons et al, take polls and ask input and yet trannys and valve jobs fall out of the sky from nowhereland. As Alice in Wonderland said...."it gets curiouser and curiouser"
#28 |
Liked 1,595 Times in 583 Posts
I know that Kevko, Canton and Milodon has the pans for the Chevy engines. Canton has the pans for the Ford and Pontiac applications. Also, I have talked to Kevko, Canton and even Joey Steffanucci (Stef's Oil Pans), they all said they can modify any stock pan with the same provisions.
#29 | |
You can run a car with 2000 pop rivets in it down the track, but you gotta pin the timing pointer? Weird. ![]() |
#30 |
http://www.camco.net/Menu.cfm?SupCat...ProductId=2216
Least expensive generator exhaust "Gen Turri" I've seen $ 106.00 |
