Hello again
It's the new Stock Eliminator guy again. Is the electric 3 speed shiftnoid legal in stock?? Thanks
C. P. 2015 Drag Pack Challenger FS/C |
Liked 237 Times in 126 Posts
Maybe if it's original parts on the trans. Here's the section from the 2016 rule book.
"Any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. (deleted stuff about converters) Electronic rpm controls for the electric (internal or external to the transmission) shifting of automatic transmissions permitted in computer-controlled vehicles only. Otherwise, any gear change must occur as a result of an internal function of the transmission or from direct action by the driver. Pneumatic, hydraulic, electric, etc. controls and shifters in all noncomputer-controlled electronic-fuel injected vehicles prohibited." Note the Internal function of the trans part. Dale
Shifnoid, no.
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
Liked 84 Times in 42 Posts
If the car originally had a computer in it, like an EFI car, then it is supposedly legal.
Bob Tilton 568 FS/H |
Liked 10 Times in 6 Posts
Wrong. Whether the car had a computer or not, only the driver can move the shifter from one gear to another. However the transmission can shift itself internally with the shifter staying in one position.
#6 | |
"Electronic rpm controls for the electric (internal or external to the transmission) shifting of automatic transmissions permitted in computer-controlled vehicles only. Otherwise, any gear change must occur as a result of an internal function of the transmission or from direct action by the driver." The terms external, permitted, computer-controlled and otherwise (especially Otherwise), muddy this up. The poster needs to clarify this with a division tech. Dale
Just a note that I did clarify it with my division tech director and he said it was ok.
Liked 68 Times in 41 Posts
Ford,chev and dodge all release electronic transmissions in 1993.so nothing before 1993 should have a Electric shifter in stock.
My 2 cents
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 02-23-2016 at 02:31 AM. |
We finally heard back from our Division Tech director and solenoid shifters are ok in computer controlled cars.
Way too much to learn in this Stock racing. Thanks guys
