Old 12-06-2007, 01:44 AM   #1
Moparteacher
Default Mopar 383 rods
Well... I've been shopping for rods for two days and it isn't promising. There are only two aftermarket rods listed to be legal. The Eagle CR6358B3D and the C&A 300-383-01S.
The Eagle 383 rod is .994 on the BE width, everything else measures correctly. I even have a new set in the garage I'm trying to sell. Stock BB Mopar is 1.014 BE width. Assembled on the crank and I have over .050" side clearance with the Eagles. That's alot of oil spray. Eagle makes a 2.200/.990 rod with a 1.007 width (a little better), but a wee bit too long at 6.385 (stock is 6.358) that's .027" too long. NHRA states +/-.025. Missed it byyyyyyyy that much!
C&A doesn't sell nor stock the 300-383-01s rod anymore. So the only two aftermarket legal rods are either obsolete or doesn't fit correctly on the stock crank.
440source offers a new H-beam with a 1.014 width and a .990 pin, but it's not on the list, yet. This leaves the stock rod. Bob Mazzolini tells me he used to spin a SS 383 to 8400 back in the day with stock rods. Those I have also, but makes me nervous.
So class, do I run the stock rod to 7800+ and hope it doesn't come apart? Do I run the 6.385 Eagle rod and hope the oil pan isn't pulled? (it's only .027") Do I run the 440source rod and hope tech thinks it's an approved Eagle rod? Do I ask Brandon at 440source to submit the rod for approval?
I'm new to this so opinions would be appreciated. Thanks
Gary Weaver
College of Southern Nevada
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
