Old 02-27-2016, 11:19 PM   #1
Jack McCarthy
Liked 477 Times in 117 Posts
Question braided fuel line
how long is it good for ?
do you all replace it every ____ years ??
cant see inside so I'm curious
what is the norm here ??
GO !
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 02-27-2016, 11:50 PM   #2
Default Re: braided fuel line
No set answer Jack, way too many variables. Quality of the hose, and type of fuel being two of the biggest. But also how long the hose was stored, and in what conditions being another big one. As well as how often the car is run, and what conditions it is stored in. Several big name suppliers have had quality issues over the last few years. I suppose the best thing to do is look at similar rubber items in your fuel system, and watch for sings of trouble, such as weeping hoses, difficulty in tightening hose connections to stop leaks, and the presence of black rubber dust in the fuel system.
Old 02-28-2016, 03:10 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
Jack, We had a buddy that flies with us had his engine go to "Net 0 oil pressure". After the engine goes back to the MFG and is taken apart and looked at no problems found. They ran it on their Dyno 5 hours. When he got it back in the plane everything looked good until he got some heat in the oil back to "0" pressure it went. One mechanic that was helping the A&P related the story to me. The plane had been down with this problem since August and the owner was about to go nuts. After a short discussion with everyone I suggested that an oil line de-laminate and closed it's self off. . It was only 5 years old. You couldn't see it looking in the hose, but when we split it open it looked like something the Dr. looks at in open heart surgery. The engine company and the plane MFG said they had never had that problem before. The lines had stayed on the plane when the engine went back to the MFG is why I think they never see it. A $128.00 oil line kit cost this guy thousands of dollars. If you have any time (age) on it change it.
Adger Smith (Former SS)
Old 02-28-2016, 09:25 AM   #4
terry1
Liked 24 Times in 13 Posts
Smile Re: braided fuel line
I have had double stainless braided hoses with Earls fittings in/on my car for over
15 years.Never a problem!
Terry K
terry1 is offline   Reply With Quote
Old 02-28-2016, 10:14 AM   #5
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I used the braided hose with a PTFE inner instead of rubber to try and avoid this problem.
Paul Merolla is offline   Reply With Quote
Old 02-28-2016, 01:42 PM   #6
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I agree with Paul , the PTFE hose lasts in our applications, but I've only used it for the main pump to regulator fuel line .
The new cloth covered lightweight stuff ,I've seen deteriorate in as little as two years.
The cheap Chinese "House Brand" hose the Speed Giants sell really deteriorates rapidly , I've had cars in the shop that had it on only one year and it was getting hard and loosing its flexibility .
Bottom line is if you think it's too old, replace it .
A couple of feet of quality hose costs way less than chasing a phantom performance problem or replacing a car due to a hose failing .
Old 02-29-2016, 11:30 AM   #7
SSDiv6
PTFE hose from Aeroquip or Stratoflex is the way to go.
It will not permeate and can last for the life of the car if you choose a good brand.
Other non-PTFE hoses need to be replaced at least every 5 years.
Old 02-29-2016, 07:33 PM   #8
FED 387
Liked 333 Times in 180 Posts
We have always used Startlite hoses the kind specifically for fuel--- light in weight, bendable and we replace them every other year and sell just the used hoses off keeping the Jiffy- Tite fittings and recover about 50% of what we originally paid for the hoses--- No problems that way--- FED 387
Old 03-06-2016, 12:19 PM   #9
Eman
Liked 133 Times in 76 Posts
I've got older SS hose on my car, I believe it's Earl's fittings and hose. Can you upgrade to teflon hose with the same old fittings?
