Old 02-29-2016, 09:51 PM   #1
Sam Capizzi Jr
Liked 43 Times in 9 Posts
Default Converter "leak"
Has anyone had an issue where the front hub of a converter leaks. I was getting drops on the ground after a run. Took converter out and no cracks on the hub where it goes in trans. The next morning I had fluid all over and it was coming from front hub (crank side).
Sam Capizzi Jr. 1301
SS/AS 93 Dodge Daytona
R/SA 73 Dodge Dart
Sam Capizzi Jr is offline   Reply With Quote
Old 02-29-2016, 10:22 PM   #2
Default Re: Converter "leak"
Sam, You would have more than just drops if the hub welding was cracked.
You didn't happen to remove and replace the front pump seal and inspect the bushing, did you?
Old 02-29-2016, 10:32 PM   #3
Sam Capizzi Jr
Are you talking the front pump seal on the transmission.. If so yes when I changed converters to my spare I did. New converter has no leaks. When i left converter on bench with fluid in it the next morning it had leaked out. Its coming from the front of the converter. Where the front hub and case come together.
R/SA 73 Dodge Dart
Old 02-29-2016, 10:48 PM   #4
Very rare, but entirely possible.
Does it have an anti ballooning plate? I ' ve seen leaks under them, where it took a while to get out to the outside.
You could rig up a cap and plug deal and run about 30 psi regulated air into it, and then check it with soapy water spray.
Any local rebuilder could make a welding pass around the hub with out disturbing anything else as long as the hub is still concentric.
You would want to drill an 1/8" hole at the outside edge near to the main weld seam.
Stand it up on it's side for a few days, then flush it out with safety kleen or mineral spirits, then blow it out good.Just mig up the hole when you're done.
Old 02-29-2016, 11:08 PM   #5
Sam Capizzi Jr
Thanks for the help mark. Ill mark the leak and get it welded and Dad can get his spare back 😂😂
R/SA 73 Dodge Dart
Old 03-01-2016, 12:45 PM   #6
John Dinkel
Liked 263 Times in 68 Posts
Sam , I had an old B&M converter that leaked. Back when I didn't have much money I brazed it and it worked. The old converter had a fiber washer and most newer converters have Torrington bearings. Probably best to send it in for repair. Good luck.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 03-01-2016, 01:29 PM   #7
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
We had one that had a leak where the snout was welded to the case. We sent it back to ATI for repair. No problems since.
Mike Pearson 2485 SS
Old 03-06-2016, 12:16 PM   #8
Eman
Liked 133 Times in 76 Posts
GM used to provide dealers with a pressure ck fixture. It went around the converter and held a plug in the snout so you could pressure test a converter. If I was pressure testing I would have something hold the plug in, like holding it with your hydraulic press or make a fixture. Many years back at a dealer I worked at they suspected a leaky converter. We didn't have the tool so 2 techs pressurize the converter with air just holding the plug, they did regulate it but it was full of fluid. We thought the converter exploded and cut them up. Instead what happened was they plug blew out and covered both of them in trans fluid.
