Old 03-08-2016, 09:00 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: oil pump help
Paint thinner is a little dry. Using solvent to check my relief valve setting, I pull the plate off the end and blow it all dry and lube everything before using it.
Ed Wright 4156 SS/JA
Old 03-08-2016, 09:22 PM   #2
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
The order of testing was oil, ATF and then thinner, so there was some lubricant in the thinner.
Ron Gusack is offline   Reply With Quote
Old 03-09-2016, 12:15 PM   #3
FED 387
Liked 333 Times in 180 Posts
just make yourself a small slide hammer to pull the dowel pins out should not take more than 20-30 minutes to fabricate one up- couple of set screws, some steel rod a 1-2 pound weight and a small collar to fit over the dowel pins, do a little drilling and tapping and you have your dowel pin remover- proceed to surface all the mating areas of the pump and rear main cap ---then either reinstall the original dowel pins or obtain new ones from an industrial supply house--- thats the way we did ours--- FED 387
Old 03-10-2016, 07:54 PM   #4
Fred D Bartoli
A carpenters claw hammer does a good job of removing dowel pins
Fred D Bartoli is offline   Reply With Quote
