Old 03-11-2016, 11:43 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Heads up runs in Stock & Super Stock
OK, thanks.
Ed Wright 4156 SS/JA
Old 03-11-2016, 12:01 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
These are what I found TPI Intakes and runners
The following airflow tests were performed on the University of Northwestern Ohio's SuperFlow SF600 Flow Bench.
All CFM values are corrected for airflow at 28 inches of water.
Injector flow rates are flowed at 43.5 PSI on an injector flow bench using test fluid with same density as gasoline.
AirFlow
Stock TPI/LT1 48mm Throttle Body w/o airfoil -- 783.0 cfm
Stock TPI/LT1 48mm Throttle Body w/ airfoil -- 821.9 cfm
TPI/LT1 52mm Throttle Body w/o airfoil -- 848.9 cfm
TPI/LT1 52mm Throttle Body w/ airfoil -- 898.8 cfm
Stock 98 Camaro 3800 II Throttle Body -- 554.3 cfm
Stock TPI Bosch MAF sensor w/ screens -- 517.8 cfm
Stock TPI Bosch MAF sensor w/o screens -- 658.4 cfm
Stock 87 GN 3.8L Turbo AC MAF sensor w/ screen -- 584.2 cfm
Stock 86 2.8L AC 5-wire MAF sensor w/ screen -- 576.2 cfm
Stock 96-up AC 3100 V6 MAF sensor w/ screen -- 616.4 cfm
Stock 96-up AC 3100 V6 MAF sensor w/o screen -- 670.7 cfm
Stock 94-up LT1 MAF Sensor w/o screen -- 719.0 cfm
Stock 85-87 Firebird TPI airbox mid piece -- 499.3 cfm
Stock 4.3/5.0/5.7 2bbl TBI complete -- 574.1 cfm (dry)
Stock 4.3/5.0/5.7 2bbl TBI w/o injectors -- 584.7 cfm
Stock 3800 vin L throttle body w/ screen -- 419.1 cfm
Stock 3800 vin L throttle body w/o screen -- 444.8 cfm
4bbl MPFI Holley Throttle Body -- 1287.6 cfm
Old 03-11-2016, 12:12 PM   #3
Dan Fahey
Dan Fahey's Avatar
From same web page
Flow (cfm) Max. NA HP
Stock 668 300
Stock w/airfoil 710 350
52MM w/airfoil 835 400
54MM (AS&M) 900 450
58MM 1050 500
Old 03-11-2016, 01:19 PM   #4
Dick Butler
Liked 32 Times in 19 Posts
Great info. Any track confirmation A.B.A?
Old 03-11-2016, 01:31 PM   #5
Dan Fahey
Dan Fahey's Avatar
Here is a similar website..
http://gmtuners.com/flow/
Old 03-11-2016, 01:59 PM   #6
Ed Wright
Ed Wright's Avatar
Carburetors are not rated at that high of a test pressure. Raise that, cfm goes up.
Flow a 750 cfm Holley or Quadrajet carb ar 28", it will show MUCH more than 750 cfm.
28" is for cylinder heads.
Old 03-11-2016, 03:06 PM   #7
Dan Fahey
Dan Fahey's Avatar
28" vacuum is standard = 1.01 lbf/ inch squared
Old 03-11-2016, 04:42 PM   #8
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
My cfm measurement is the timeslip! :-)
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
