Old 03-23-2016, 10:12 AM   #61
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: Oil starvation issues SBC HELP?
Originally Posted by joespanova View Post
Man you are a grumpy old azz aren't ya?
Do you read my replies? If you did you wouldn't say that.......geeezus christ. Am I dealing with men here....or women?
For the second GD time.....I AM listening / reading.
You're also the one that says throw a windage tray away when almost all others say they work?
Joe i run the same pan ,and found out i couldnt run less than 6 1/2 quarts the engine would lose pressure, still have the pan but always run 6-7 quarts with no pressure loss.I run 2.2 and 2.7.
Old 03-23-2016, 10:20 AM   #62
joespanova
Liked 13 Times in 11 Posts
http://www.ebay.com/itm/Moroso-21015...dW6ZCr&vxp=mtr
This is the EXACT pan I have.....
Old 03-23-2016, 10:37 AM   #63
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
The only time I have had oil pressure issues on SBC that I have assembled is when I had a 3/4 diameter pick up,whether it was windage or the pick up,I don't know?? but i do know I switched to 5/8 pickup and my issue went away ,I don't know if anyone else has had same experience,but I have on two different engines.
Mike Taylor 3601
Old 03-23-2016, 10:41 AM   #64
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
[QUOTE=joespanova;499144]http://www.ebay.com/itm/Moroso-21015...dW6ZCr&vxp=mtr
This is the EXACT pan I have.....[/QUOT
I ran one of those Moroso pans for many years with no oil related issues. I doubt it is the pan causing problems. What oil and filter are you running? I don't run any passenger car oil or filters any more I also run a billet Moroso oil pump as well. Idles at around 35 and about 80 in the lights. I also have an idiot light to warn me if the pressure drops below 15 lbs.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 03-23-2016, 11:44 AM   #65
Ed Wright
Ed Wright's Avatar
I use that pan. Pickup 1/2" off the bottom. No tray (one of the top engine builders in the U.S. recomended leaving it out), have a baffle plate at the back to try to stop oil going up the back at launch. Stewart LOW volume oil pump. 60 psi in the lights, 30psi, warm idle. Warning light set to 20 psi. Bracket/slow down mode: 6qts of 10W30 Valvoline in the pan for "bracket"/slow down mode. Always a 1061 NAPA Gold oil filter. 4 qts of Zero-10wt RP for a tough heads up. Don't usually need it. I often run bearings two seasons, still look like new, sometimes go ahead and change them due to guilt. Have a drawer full of new looking used bearings.
Ed Wright 4156 SS/JA
Old 03-23-2016, 12:26 PM   #66
joespanova
[quote=Mike Pearson;499150]
A Wix 51060 racing filter. At this time it has Brad Penn 30wt break in , in the pan.
Old 03-23-2016, 12:27 PM   #67
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Exclamation Re: Oil starvation issues SBC HELP?
Do you use screens or baffles in the lifter gallery??
The more people I meet the more I like my dog
Kevin
Old 03-23-2016, 12:30 PM   #68
joespanova
OK , Ed ..thats useful....thanks.
I thought you said you are using the "newer" version below: The E-bay pan is NOT the same pan......maybe the one below is a better pan?
Old 03-23-2016, 12:33 PM   #69
joespanova
No
Old 03-23-2016, 12:56 PM   #70
joespanova
OK......
I've had some beat me up over 20 yr old pan design I have.............so I just bought a Moroso 21017 as pictured.
Hope it helps.
