Old 03-28-2016, 08:29 AM   #1
Eman
Liked 133 Times in 76 Posts
Default Brake Pressure light on dash???
I recently saw an in car video of a SS car. I noticed when staging he had a light on the dash that would come on as he pumped the brakes while staging. Anyone use this? What switch and what pressure is it set to?
Old 03-28-2016, 08:34 PM   #2
Tim Ellis
Liked 7 Times in 6 Posts
Default Re: Brake Pressure light on dash???
It probably comes on when brake pressure meets the preset amount needed to activate the 2 step. Folk race cars has a brake pressure switch , called Answer, used for activation of a 2 step. The switch is adjustable pressure wise . So it depends on how high you set it .
Tim Ellis is offline   Reply With Quote
Old 03-29-2016, 08:15 AM   #3
Eman
I've got a preset switch that activates my 2 step. I saw the light and figured it was on an adjustable switch. The light is a good idea instead of looking at a gauge, just wondering what pressure it would be set at.
Old 03-29-2016, 04:25 PM   #4
Danny Ashley
Liked 110 Times in 29 Posts
I put "The Answer" switch on a fellow racer's Stocker a few years back with the light and his car already had a brake pressure gauge. I would assume the pressure would vary depending on the brake type and master cylinder bore size, but his car would hold good at 800psi and you didn't have to push that hard on the pedal. It had Mark Williams 4-wheel discs w/ dual calipers on the rear.
Danny Ashley is offline   Reply With Quote
Old 03-29-2016, 05:21 PM   #5
65signet
Liked 49 Times in 22 Posts
I run a light in my car, so i know that i am pushing brake pedal hard enough, to activate the 2 step, works great no guessing.
65signet is offline   Reply With Quote
