Old 04-03-2016, 07:57 AM   #1
SuperStock 1890
SuperStock 1890's Avatar
Default More room in garage needed
2 sets of 8 of Accel 150824 24 lb. injectors. Fresh back from being cleaned and tested. $125 per set.
New Tom Russell torque arm with cross member. $175
New LT1 stocker short block .060 over with JE pistons with 1.2 mm Total Seal rings with spacers, Napier second rings, low tension oil rings. Lifter bushings. Limited travel lifters. Manley rods. All block work done by Charlie Weston. Comp Cams cam. Email for more details.
Steel weight & battery box for Gen 4 Camaro. Bolts in across trunk well. Weight of box 45 lbs. $75
LT1 stocker long block. Good for someone starting out. Older technology. Lunati pistons, Bullet cam, lifter bores bushed. Heads were originally done by Woodro and freshened years ago by Modern and still in bubble wrap. $1800.
Shipping is on you from Atco NJ.
Richscaz@hotmail.com
You don't know what you don't know yet.
SuperStock 1890 is offline   Reply With Quote
Old 04-03-2016, 09:08 AM   #2
nhra63corv
Liked 3 Times in 2 Posts
Default Re: More room in garage needed
Can you give more details on the short block, I currently have a GT/FA. Car running the 68 Camaro 327/275 combo looking for another engine combo/ back up. thanks Jeff
nhra63corv is offline   Reply With Quote
Old 04-03-2016, 08:53 PM   #3
SuperStock 1890
Jeff check your PM.
Old 04-18-2016, 05:36 PM   #4
Kenney Kelley
Liked 72 Times in 36 Posts
Richard I received my parts today Thank You Kenney Kelley
Thank You Class Racer
Kenney Kelley is offline   Reply With Quote
Search this Thread:
Advanced Search
