Liked 101 Times in 27 Posts
When water pump, fan, or driver failure creates a 1/4 mile pass that reaches the 230 plus zone, how hot is too hot or at least hot enough to create damage for that short length of time ???
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Rusty,
Every motor and combo is a little different. Aluminum block? Aluminum heads? Did it puke the water out of it? Does it look and sound ok after cooling off? New stuff is set up to run at 210+ from the factory for hours on end... I would just check everything out visually. Might run it a little and change the oil and filter and cut the filter open and check it. If all looks good, run it. If you find too much "gold dust" in the filter, then might have to rethink it... I have had sbc w aluminum heads get up to the 230ish number when electric water pump quit and I did not catch it until turn off, during a TX summer. Did not hurt anything luckily. Good luck with it. Ken |
Banned
Liked 179 Times in 89 Posts
Too hot is when the coolant reaches its boiling point.
Engine will run all day long at 250* as long as the coolant isn't boiling. |
Liked 56 Times in 27 Posts
Rusty,
As Ken said , check everything over really close... Try another H2O gauge to be sure yours isn't stuck & see if they read the same ?? Also, make sure there's not restricted area or plate anywhere in the engine, hose, radiator etc. I would then try letting the engine run @ 2-2500 RPM & see how long it takes to get to 220-230 * degrees temp ??? Sounds like you have something restricting the flow, try draining everything and see what comes out. When did you start having this problem, after the fire or before ???? let me know.... Are you coming to VMP this weekend ??
Dave Ribeiro 1033 STK |
What kind of car is it Rusty? Some of these later models are hard to get all the air out of the cooling system. I added bleeders on the back of my heads to get the air out, while the electric water pump is running. Engine off. If mine gets to 160 in the shut down area, it's back to 135/140 by the time I get back to the pits. 230 is pretty hot in a short time.
Ed Wright 4156 SS/JA |
Liked 254 Times in 78 Posts
I had similar issue, was wondering if can hurt the rings, causing bad leak down numbers.
Mike Moller NHRA 203 Q-R-T/SA |
Liked 240 Times in 112 Posts
Had that happen a few times. Didn't hurt anything, except my nerves.
Dave Noll, EF/S ,?/SA 6526 |
