Old 05-07-2016, 07:47 PM   #31
Default Re: 68 chevelle suspention
No? Here it is again:
Originally Posted by 1320racer View Post
This^^^
completely bolt in and replaces every part of the factory suspension.
Went a best of 1.28 60 foot launched off the footbrake at 3880 lbs. 9 years ago.
Old 05-07-2016, 08:33 PM   #32
HP HUNTER
Liked 373 Times in 129 Posts
a street car doesn't mean it's a daily driver and the only books that counts here is the OP's.
No confusion about it, Abbezia's former chevelle didn't 60 foot 1.28 and it didn't weigh 3880 lbs. but my Chevelle did!
1.288 @ 3880 to be exact, Ed, just how much do think a 71 LS6 has to weigh in B/SA? And BTW many many years ago it also went 10.00 in B/SA. As far as my Chevelle and Johns go your not going to want to talk about that. Both cars that would leave on your Chevelle like you were going backwards, both stock suspension, both GM production oval ports.
Name:	vortec chevelle 1.jpg
ID:	33930   Click image for larger version
Name:	Vortecpro 496 JW.gif
Old 05-07-2016, 09:34 PM   #33
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Again, Abazzia's former chevelle never went 1.28 in 60 foot nor did it weigh 3880 lbs.
Old 05-07-2016, 09:49 PM   #34
HP HUNTER
Ed, do you see the designation B/SA on the rear side window of Joeys 71 Chevelle?
Ed, would you agree Joey ran his Chevelle as a 1971 LS6 454 combination?
Old 05-07-2016, 09:51 PM   #35
1320racer
1320racer's Avatar
that car hasn't been "Joeys" in nearly 10 years and no one cares what that ILLEGAL car ran when he owned, least of which is the op that asked about the best suspension for his '68 Chevelle. What it didn't do is 60 foot 1.28 nor did it weigh 3880 lbs. FACT!!
Meanwhile, you've never met abbazia, never seen the car in person, don't have a clue to where it is now. All of which I have and do!
Old 05-07-2016, 10:05 PM   #36
HP HUNTER
Ed, again I know I have to take it slow with you........
combination?
"Meanwhile, you've never met abbazia"
Are you sure?
435 NHRA HP X 8.50 = 3697.5 + 170 = 3867.5 B/SA now you all know where Ed arrived @ 3880 and 1.28 60 foots, mesmerized by Joe Abbazia's 1971 B/SA LS6 Chevelle.
Do the work.....get the results.
Old 06-05-2016, 11:23 PM   #37
Bernhard
Last time I checked Alf's suspension is not for street use.
His track record for building cars that work speaks for itself.
Bernhard is offline   Reply With Quote
Old 06-12-2016, 01:08 PM   #38
larrylomascolo
Liked 66 Times in 29 Posts
I own a 69 chevelle bracket car that sits these days,i used the right rear air bag ,it hooked o k,these days i see anti roll bars and adj control arms,,,If were you go look at Charles Sousa black 69,dont know whats under his hot rod but it leaves strait up 3ft wheels up,I/SA car,
