Old 05-08-2016, 10:28 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Re: Total Seal ring question
I was curious because that set is less than $400 and I was thinking they were normally around $900. And I haven't decided between JE or CP pistons yet
jamie2370 is offline   Reply With Quote
Old 05-08-2016, 11:40 PM   #2
Either piston company will be fine, I use both.
I usually spec out my own ring set with help from Keith, I also do my own gas ports in the spacers, and build my oil ring with open stock parts from Speed Pro, so I'm not real sure what the out the door price is on a complete ready to go package.
Old 05-09-2016, 09:00 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
If you talk to Darrin at Patterson about your pistons he can coordinate the ring combo with Total Seal. As Alan said Keith at Total seal will help you get the correct parts and coordinate with your piston manufacturer to get the ring lands correct for the ring package.
Mike Pearson 2485 SS
