Old 05-25-2016, 09:44 AM   #61
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
Default Re: LIVE from Summit Motorsports Park - D3 LODRS
It looks to me like, in the final, Allison's stage bulb first lit at 2:41:35, then went out, then came on for good at 2:41:39. Merkle's red light came on at 2:41:45. It seems that he should have had 4 more seconds, until 2:41:49.
In the round against Novosel, Allison's stage bulb came on at 1:35:30, and Novosel was red-lit at 1:35:41. It seems there was the full 10 seconds here.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 05-25-2016, 10:34 AM   #62
Liked 10,767 Times in 2,238 Posts
I believe the clock starts when three bulbs are on and does not reset if it goes back to only top bulbs lit. It looks like it was set on 10 second for automatic red. I could be wrong.
Old 05-25-2016, 01:35 PM   #63
Ellis V Buth
Liked 406 Times in 70 Posts
I believe this is correct. I have seen the car that originally flickered the bulb get timed out before in this exact same scenario. Actually, he unintentionally double bulbed and backed out of stage...but the opponent was already pre-staged and bumping in so by the time the original "staged" car got his RPM's to where he wanted and started bumping, the red came on in his lane (about 10 seconds from his original staging snafu).
Ellis V Buth is offline   Reply With Quote
Old 05-25-2016, 08:21 PM   #64
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
There is a "Staged Minimum" setting in Autostart (typically 0.6-0.7) that prevents Autostart from being activated by just a bare flicker. If there are two pre-stage bulbs lit and one of the Stage bulbs is lit for more than the Stage Minimum time, then Autostart is active (and it does not reset if a car backs out).
Both instances were legitimate timeout redlights.
