Liked 118 Times in 41 Posts
Ford 302's came with a 28oz imbalance crank till 81 (i think). After that a 50oz crank. I'm building a 79. Can I use a 50oz crank or does it have to be 28oz?
U/SA 79 Mustang |
The crankshafts approved for each year, make, and model, are listed by number in NHRA Racer, Technical Section, Engine Blueprint Specifications. That should easily answer your question. If I was building an engine, I would become very familiar with this material.
Jeff Blanchard 353C / Stock |
If you are going to use a production 50 oz. crankshaft there is no issue. Heads and intake are the only critical parts to vintage, any year block, crank.
Thanks Lou, thats good news. i have a 88 block and crank given to me that looks like new. I was hoping I could use it. I have the right heads and intake.
U/SA 79 Mustang |
Liked 275 Times in 76 Posts
Lighter is better, or internally balanced. It does not matter on the crank what vintage it is, as long as the stroke is within blueprint specs. It would be a good idea to have the crank checked. I had a cast crank break on the dyno and it pushed the front of the block out.
If your 50oz is what you have then your good. You just need the matching flywheel of flex plate. Sean
Liked 70 Times in 29 Posts
spend the money and get a good balancer no matter which crank you use. Don't use one of the factory balancers unless you don't plan to run much rpm.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 251 Times in 125 Posts
Is a roller cam block (your 88) different than a flat tappet block (79)?
It's not a roller block. It's a YYY block with a one piece rear main.
U/SA 79 Mustang |
Liked 317 Times in 108 Posts
when you have your engine balanced,have it done with the balancer and flywheel you are going to run.
There is quite a bit of difference in external balancers,flywheels and can make a big difference in the balance of your crank,if is stick have pressure plate done also. if had a choice and had to be external balance,I would use 28OZ before 50OZ , 28 OZ will flex crank less. If you use 50 OZ crank you will have to use 50OZ balancer and flywheel in case you didn't know. Mike Taylor 3601 Last edited by Mike Taylor 3601; 05-26-2016 at 08:16 AM. |
That's the plan. I'm getting a new balancer and flex plate for sure. The motor wont see a lot of RPM so I'm not worried about crank flex so much. I needed to buy a crank and got this one for free so I cant complain.
U/SA 79 Mustang |
