Old 05-26-2016, 08:14 AM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 317 Times in 108 Posts
Default Re: Ford 302 crank
when you have your engine balanced,have it done with the balancer and flywheel you are going to run.
There is quite a bit of difference in external balancers,flywheels and can make a big difference in the balance of your crank,if is stick have pressure plate done also.
if had a choice and had to be external balance,I would use 28OZ before 50OZ , 28 OZ will flex crank less. If you use 50 OZ crank you will have to use 50OZ balancer and flywheel in case you didn't know.
Mike Taylor 3601
Old 05-26-2016, 02:30 PM   #2
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
That's the plan. I'm getting a new balancer and flex plate for sure. The motor wont see a lot of RPM so I'm not worried about crank flex so much. I needed to buy a crank and got this one for free so I cant complain.
U/SA
79 Mustang
