#1 | |
Liked 5,151 Times in 1,966 Posts
Make sure, if NHRA calls you up for your thoughts, that you tell them that you Ed Fernandez, doesn't need to deep stage ..Therefore nobody else does either. Okay buddy?
Liked 181 Times in 56 Posts
Mike Jeffrey has probably one of the slowest leaving cars in Stock and can get ahold of the tree pretty good shallow staging. All it takes is practice, practice, practice.
Sorry, that's not correct.
If you are looking at the tree wrong , you can practice till hell freezes over , and you'll never be consistent and good at it.
Liked 55 Times in 17 Posts
Liked 3,025 Times in 724 Posts
Mark you are correct. You have to find that sweet spot on the tree. If you don't leave at the same spot consistently then what's the point.
Also, I have seen several people use a shorter front tire to help with the reaction time. That might be a crutch, but it works for them. Adjusting front tire pressure helps, also. Just my 2 cents.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
Liked 36 Times in 26 Posts
I would prefer the question to be, "only the stage bulb is required to race. Make it like the pros, only the stage bulb is required for you to be staged. The prestage, original intent was to let you know you are getting close to the stage position. Don't call it deep staging, where you got to put it on your window, to make people wait on you to roll in. Make it so only the stage light needs to be on to race. Courtesy staging is not courteous, get rid of the courtesy staging, and bring some drama back to the starting line. Steve Williams S/G
#7 | |
Liked 17 Times in 12 Posts
Marty Hanft |
#8 | |
Liked 508 Times in 92 Posts
Casey Miles 248H Stock |
Liked 1,865 Times in 435 Posts
Dead horse
james perrone 1290 STK |
