Old 05-31-2016, 12:30 AM   #30
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: 350/255HP Help please
Originally Posted by Alan Roehrich View Post
Agreed. Cold leak down is useless. Honestly, on these engines, you need to be using a Dwyer gauge, or something, to test blow by on the dyno. Leakdown, even hot, can be misleading. Measuring blow by eliminates all of that.
Alan, could you describe how the Dwyer gauge works?Is it basically installed like a vacuum gauge? I've never heard of one.Looks like there are several different calibrations.Which is correct to use to measure ring seal as you described? Thanks,Mark
