Liked 8 Times in 3 Posts
Hi all
Having a problem with my car, just installed a new 8" converter that should flash around 5000, I launch foot to the floor on a 2 step @2500 rolls about 5 feet or so kind of feels like a "buck" car sort of bounces , it's killing my 60' time and what ever it is it doing the same every time combo is 255/350 69 camaro ,ps fuel pressure is 5.5 psi |
Liked 239 Times in 114 Posts
If all you changed was the torque converter, then I would suggest putting your old converter back in and see if your problem goes away .
It's leaving more violently until it starts bucking
Lost about a tenth and the density altitude was 9600 ft |
Liked 10,819 Times in 2,248 Posts
fuel spill over?
I'm not positive about spill over no one saw any smoke but not sure if it would smoke as fast as it happens
I had spill over several years ago when I still ran a carb. No smoke. Larry is likely correct.
Ed Wright 4156 SS/JA |
Liked 1,877 Times in 422 Posts
Yes, odds are there is fuel splashing out of the float bowl through the vent, or where the secondary metering rods are.
There is a baffle found on late model carburetors that may help. It is held on by the two screws on the air horn directly behind the choke tower.
Alan Roehrich 212A G/S |
Air horn baffle?
http://quadrajetparts.com/used-horn-baffle-p-2428.html
and P 36 on here http://www.gmcmi.com/wp-content/uplo...ice-Manual.pdf
old 1608 stock racer |
