Liked 84 Times in 21 Posts
Maybe drill a hole on either side of the nut shoulder then plug weld it?
Liked 886 Times in 238 Posts
Most commercial fastener distributors have expanding insert nuts like Riv Nuts and other brands .
Most areas have a Fastenall store nearby . Make sure you use the heavy duty style for the proper thickness of the frame , There are different types for use and gauge of metal.
Liked 28 Times in 15 Posts
Thank you for the replies. I will find the Fastenal in San Antonio. In the meantime I will look up these rev nut things and get familiar with them.
Found a Fastenal store in New Braunfels TX, they gave me a catalog and told me the Rivnut tool can be borrowed from Auto Zone. Just have to get right size nut, I think its 10 mm for the crossmember bolts.
I use a bolt and flat washer to install riv nuts when I don't have the correct threaded insert for my riv-tool.
old 1608 stock racer |
Liked 133 Times in 76 Posts
Mine gave up a while ago, too many trans changes. I just drilled out and retapped the originals to a larger SAE size.
Eman were they loose in the folded sheet metal frame? Auto Zone never heard of that type of rivet gun BTW. Hope to work on it again tonight.
