Old 06-17-2016, 09:22 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Re: Trans Bolt Holes 3rd Gen Camaro
Yes ss3011 that's what's happening. Didn't get home in time to work on it last night.
brian schuetta is offline   Reply With Quote
Old 06-17-2016, 01:17 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
I figure the biggest problem is getting out the old nut, if you have to cut it out, then I guess you could just weld in a new nut , Domm suggested welding the existing nut, If you can get at it , that would work. You could use the rivnut idea, but install it in a different place, so you wouldn't have to get the old nut out . I think you could make your own tool with a longer bolt, nut and washer , you could then hold the bolt, while you tighten the nut, this would pull on the insert , without spinning it . Worth a try !
ss3011 is online now   Reply With Quote
Old 06-17-2016, 06:12 PM   #3
Liked 5,134 Times in 1,958 Posts
Drill it out clean
Put the nut-sert in the hole and tack the lip 2,3 spots.
Grind flush.
Pull the insert down with a washer and bolt.
Old 06-21-2016, 08:20 AM   #4
brian schuetta
Ok to get a better idea of what was inside the frame I put a drill through the bolt hole from the bottom and through the floor, of course I took out the front seat and rocker cover and moved the carpeting. Then took a 1 1/8"hole saw and cut a hole in the floor centered on the previously drilled hole from below. There it was but not what I expected it to look like. So now the nut is too far down the hole for my MIG welder tip to fit without opening up the hole larger. Will get back to it tonight when I get someone to try to screw a bolt in while I watch from above.
Old 06-21-2016, 10:53 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
You might be able to use a stick welder with a small rod and low amperage. All you want to do is secure the nut, right?
Old 06-21-2016, 11:04 AM   #6
brian schuetta
Yes that's all Im trying to do. I guess I could borrow at stick welder, all I got at home is an old used MIG machine. BTW I never got to use those nickel rods to tack the oil pump pickup so maybe if I borrow a stick welder I could see how that works too.
