Old 06-18-2016, 07:44 AM   #1
Lou Jeffery
Default Re: M-200 torque converter installation
Bobby, I think you are not engaged with the pump drive yet. I measured a stock 200 with converter and mount pads are 1.125 inches behind the mounting surface. The pump drive, The two square notches on the neck of the converter are the last part to engage. Hope this helps. Louis Jeffery
Lou Jeffery is offline   Reply With Quote
Old 06-18-2016, 10:00 AM   #2
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
I had an issue with a 200 like this a number of years ago. My solution was to stand the trans up vertically (I used a trash can to hold the trans) and install the converter. It dropped down on the input shaft easily that way. Be sure not to let the converter move and muscle it back under the car. Not fun, but it worked.
Old 06-18-2016, 10:17 AM   #3
R. Thorne
Liked 100 Times in 33 Posts
If you have access to a mike (or dial caliper) measure the torque converter snout o.d. of both converters. Just .001" bigger could be holding up the converter from seating fully. Sometimes just putting in new front pump bushing can do the same thing. Also, check for a burr on the end of the torque converter snout. Ron.
R. Thorne is offline   Reply With Quote
